turbo parts intake accordian injectors HKS MHG stock bov ct26 Msd blaster coil
Email: [email protected]
Pm: yes
Selling these parts don't need them anymore
rising rate fuel pressure regulator 6:1..................................$50 shipped
AEM Bruteforce air filter 2.75" inlet 9" long new.....................$50 shipped
315cc 7mge injectors high impedence..................................$35 shipped
Greddy bov flange alum pipe 2.5inch with screws new.......... .$35 shipped
used HKS 2mm Stopper metal head gasket..........................$70 shipped -- cost $300 new
will the msd coil plug up to a 89 7mgte harness?? does it give any extra hp?? lmk, might be interested.
it would only work on single coil setup. 7mgte uses 3 coils. it would replace the stock 5m coil, doesn't plug in, needs to be wired
oh ok got ya... well i wont have my 5m much longer ha...thanks tho!
these injectors are from the later 7mge with high impedence, so i woudln't suggest using them unless you have standalone or aftermarket ecu setup that supports high/low, or the
7mge which came with these. i used them on a old setup and i had to bypass the resistor injectors didn't like to open when it was cold out
