thanks for your input.
i am going to go ahead and put a CT26 on my 5mge. i am buying a manifold off a 7mgte off EBay right now.
Currently there are two CT26 turbos on Ebay both are a little over $100 dollars at the moment but i dont know enough about turbos themselves to place any bids right now. Any suggestions on them? item numbers 2409668155 and 2409656025.
also there is a farely large intercooler (2409613694) but the openings are on opposite ends which im sure will make routing the plumbing a bit more difficult. Does anyone know if it will fit? 28" x 14.5" x 2.25" end tank to end tank. its in houston too so i could go pick it up and save on shipping
or would i be better off with a stock 7mgte intercooler?
do any of you recommend a fuel pump upgrade or will a rrfpr work just fine for the CT26?
how about the ignition system? what type of aftermarket components are any of you running?
i dont plan on "jerry rigging" anything. this car is drivin daily but i could get by with stealing my other car from my girl for a little while. i dont have hundreds of dollars to spend so im looking to buy a used turbo. when shopping for a used turbo, what should i look for? what is a good price for a CT26 in good shape?
i work in a CNC machine shop so i can make custom peices i might need. also i have a friend that owns a metal fab shop where i can fabricate my intercooler piping and oil return line.
hopefully i wont have 1500 to 1800 dollars wrapped up in this project like you mentioned. but i will do what needs to be done to prevent my engine from grenading on me.
what kind of rates am i looking at to have this tuned on a dyno with a gas analyzer?
thanks for all your help,
Nate
