okay, so:
get in today, start the car, let it warm up, everything is tickety boo.
put it into 1st, drive out of parking lot... coast to stop sign. put it into neutral to stop. start out again, rev up, let off gas and put in clutch to shift. engine dies.
i coast to teh side of the road, try cranking it... won't start, cranks, but won't start. pop hood, check fluids - oil, brake, clutch, all good. no major leaks under the car, no bad smoke or smells. air filter dry, distributor and plugs/wire dry.
i give it a couple minutes, then try cranking it again. evnetually it starts. goes to idle. i tap the gas a few times, bring it up to 2000rpm roughyl, let it drop to idle. it stays alive. put it into gear and pull out. turn left and start accelerating. clutch in, gas out, engine dies before i get into 2nd. after waiting some more, and cranking it, it eventuially starts.
i let it sit at idle for a few seconds... and then the rpms start jumping all over the place ebtween 500 and 1500 rpm. it gets all rough, slowly dropping (while still spiking and jumping) until it dies.
basically, i can't get it to stay started... sounds likea fuel issue, the way it dies. my dad (mechanic), my step mom (engine parts sales) and one of my buddies (restoring a 73 240z, L28, triple weber 45's), all figure it's fuel related. fuel filter is most likely. when it gets wild idling, it feels like what happens when a car runs out of gas basically.
i figure the reason it died int he middle of shifting is becuase when i let off the gas, not enough pressure, or shear volume, of fuel was gfetting through at the idle setting becuase the fuel filter is toast, so it died.
it was raining, and cars were goign by, so i couldn't hear if the fuel pump was still priming when you turn the key to on. i can't hear it inside the car normally anways, so i have to get someohe to listen for me.
basically,t eh car is sitting at UBC, i took my girlfriends car home tonight, but i NEED that fuckign car fixed. i may have 4, but it's the only running one. as it stands, i'm buying a fuel filter regardless, and taking al my tools in to fix the damn thing tomorrow... in her residence parking lot.
any other ideas... am i missing anything?
ps: i've also seen it, very rarely, while driving it will hiccup once or twice, as if it loses fuel... but it literally has happened 2 or 3 times in about 2 weeks of driving 60km+ per day.
