1 - 5 of 5 Posts
An 82, 83 and 3 84 P-types.
Stumbled across this while hunting for ST springs. Perhaps not everything is still available but part numbers are sure handy when you're searching.....
Toyota Supra (82-85)
ACT Clutches:
Performance Pressure Plate:
81-85, T-021, (+35%), $208.89
Performance Street Disc:
81-85, TYSD018M, $83.03
Solid Racing Disc:
6-Puc Very Aggressive Contact, $99.20
4-Puc Brutal Contact, $82.59
Release Bearing;
81-85, RB201, $18.01
ADDCO Sway Bars:
1-1/8" Bar, Front, 745U, $163.80
3/4" Bar, Rear, 375U, $141.75
AEM Tru-Time Adjustable Cam Gears:
Replace * with B for Blue, C for Clear/silver or R for Red
81-85 5MGE w/round tooth, 23-614*, $168.77 each
Corbeau Seat Brackets:
82-85, Driver Side, 22041L, Passenger Side, C22041R, $64.25 each
**** Go to the Manufacturers Tab and see all the Seats in the Corbeau line **
Crane Fireball HI-6 Ignition and PS-91 or PS-92 Coil:
6000-6420, $202.22
730-0091, $50.31
730-0092, $71.74
(For simplified installation, add this: 6000-8950, Universal Trigger Adapter, $78.74)
(Most Japanese Imports [except Honda] also require the 6000-8910 Tach Adapter, $31.95, if the 6000-8950 is not used for installation)
Cusco Japan Strut Tower Bars:
Front Bar, ST Type, 180510A, $121.44
Rear Bar, AS Type, 180511A, $121.44
Doug Thorley Header (50 state legal!)
530Y, $362.25
Eibach Pro-Kit Springs:
8221.140, $235.24
Energy Suspension Bushings:
Front End Control Bushings, 8-3101, $13.58
Rear End Control Bushings, 8-3112, $21.56
Front Strut Rod Bushing Set, 8-7102, $16.60
Front End Link Set, 9-8122, $15.08
Fidanza Lightweight Aluminum Flywheel:
81-5/93, 130551, $361.00
GAB Super HP Adjustable Shocks/Struts:
82-85 Front, GSZ1080A, $
Rear, GSA1550, $
Goodridge Stainless Steel Brake Lines:
SEE TECHNA-FIT
Granatelli 255 liter per hour Fuel Pump:
84-92, all, Model 315/341, $125
Capable of supporting over 500 HP
Some modification may be required!
Greddy Turbo Boost Controllers:
Profec A Spec (Fuzzy Logic), 15500203, $523.60
Profec B Spec (Electronic), 15500202, $369.60
Profec B Spec Clear Blue (Electronic), 15500204, $351.12
HKS PFC F-CON Fuel Computer Harness:
85-86 5MGE (for turbo conversion), 4202-RT009, $118.80
82-84 5MGE (for turbo conversion), 4202-RT008, $70.40
email for F-CON chip availability
HKS Super Mega Flow Intake:
82-86 5MGE, 1504-SA007A, $105.60
replacement elements in Blue, Gray, Green, Orange, Purple & Yellow - $13.20
K&N Filtercharger Air Filter:
E-2487, $38.34
K&N Filter Care Kit:
99-5050, $7.95 (Squeeze Oil)
99-5000, $9.45 (Aerosol Oil)
K&N Performance Gold Oil Filters:
HP-2004, $9.75
Koni Strut Cartridges and Shock Absorbers:
82 - 2/86, Front, 8641-1041, $Discontinued
82 - 2/86, Rear, 28-1132, $95.55 ea
KVR Performance Carbon Fiber Semi-Metallic Brake Pads:
82-85 Front, M7408, $55.52 set
82-85 Rear, M7129, $50.95 set
KVR Performance Cross-Drilled or Slotted Brake Rotors:
82-85 Front, TO-608CD, $63.90 each
82-85 Rear, TO-621CD, $82.80 each
** Cadmium Plating add $15.00 each **
** Cross-Drilled & Slotted add $25.00 each **
KYB GR-2 Gas Strut Cartridges and Shocks:
Front, 365076, $45.71 ea
Rear, 343042, $25.37 ea
Magnecor KV85 Competition Spark Plug Wires:
5MGE, 6575, $75.88
Pacesetter Monza Exhaust System:
82-84 GTS w/ IRS, 88-1305, $178.71
(Requires modification to fit the '85)
Pacesetter Black Paint Header:
70-1110, $200.16
Pacesetter Armor Coat Header:
72C1110, $364.61
Perma-Cool Engine Oil & Transmission Cooling Products:
Universal Engine Oil Cooler Kits:
150 HP 3/4"x7-1/2"x12-1/2" Remote Style, 69195, $92.12
150 HP 3/4"x7-1/2"x12-1/2" Sandwich Style, 69189, $85.44
250 HP 1-1/2"x7"x14", Remote Style, 10195, $110.62
250 HP 1-1/2"x7"x14", Sandwich Style, 10189, $104.10
450 HP 1-1/2"x7"x21", Remote Style, 40195, $181.64
450 HP 1-1/2"x7"x21", Sandwich Style, 40189, $187.38
Oil Cooler Kit Accessories:
Trans Remote Mount Kit, 102, $7.73
Metal Mounting Kit, 103, $3.98
Nylon Tie Mounting Kit, 105, $3.75
Temp Gauge Kit, 15106, $53.50
Oil Filter Relocation Kits:
Single Oil Filter, 10695, $47.32
Dual Oil Filter, 10795, $62.59
Automatic Trans Filter Kits:
Standard Kit w/Filter 10678, $38.90
Deluxe Kit w/Filter & Gauge 10677, $79.31
Turbo Flex High Performance Electric Fans: (Reversible Push/Pull)
10" Fan, Mounting Area 13"x10-1/2"x2-1/2", 19010, $92.84
12" Fan, Mounting Area 12-1/2"x12-1/2"x3-3/4", 19008, $105.18
14" Fan, Mounting Area 14"x14"x3-3/4", 19114, $120.79
16" Fan, Mounting Area 16"x16"x3-3/4", 19115, $127.15
18" Fan, Mounting Area 17-3/4"x17-3/4"x3-3/4", 19117, $140.23
Turbo Flex Electric Fan Accessories:
Wiring Kit w/170 Degree Thermal Switch, 19001, $19.56
Electric Fan Wiring Kit, Adjustable (Probe), 18905, $55.08
Metal Mounting Kit, 104, $4.06
30 Amp A/C Relay, 19002, $8.33
Suspension Techniques Anti-Sway Bar Kit:
Not Available
Suspension Techniques Sport Lowering Spring Set:
60390, -1.3", $205.07
Techna-Fit Coated Stainless Steel Brake Lines:
82-85, TOY-1330, 8 Line Set, $162.00
Available in red, yellow, blue, black and clear
Tokico Premium Performance Strut Cartridges and Shocks:
82-85 HZ3062 Front, $61.74 ea
HE2483 Rear, $35.07 ea
Tokico Illumina Adjustable Strut Cartridges and Shocks:
Front, BZ3062, $116.50 ea. discontinued
Rear, BE2321, $98.14 ea. discontinued
Tokico Premium Springs:
Not Available
Topline:
Gold Engine kit:
7/82-84, 5MGE, EKT019G, $553.63
Contains complete gasket set, set of pistons and
rings, main bearings, rod bearings, thrust washers,
timing belt, balance shaft bearings (if applicable),
set of expansion plugs, and oil pump.
http://www.cyberauto.com/index.php/ToyotaSupra(82-85).txt
...and only 5 hours earlier! What are the chances? Well, it will get more attention in 2 forum areas.....
That is the first Supra parts web site I ever saw back in 1996. It doesn't look much different then it did then. Got me really excited about the possibilities.
1 - 5 of 5 Posts
