84 TSRM INFO
This I found in the tsrm, maybe helpful, not sure about the outer diameter :?
A. Using steel square, checking squareness
Max allowable 2.0mm (0.079in.)
B. Free Height:
Intake side 49.1mm (1.933 in.)
Exhaust side 52.5mm (2.067 in.)
C. Spring tester-if not this, replace.
Installed Height:
Intake side 40.0mm (1.575 in.)
Exhaust side 43.0mm (1.693 in.)
Installed tension:
Intake side 34.7-38.3 Kg, (76.5-84.4 lb, 340-376 N)
Exhaust side 33.3-36.7 kg, (73.4-80.9 lb, 327-360 N)
B. Free Height:
Installed Height:
Installed tension:
