1 - 2 of 2 Posts
135 - 150 - 148 - 30 - 0 - 50 (From 1-6). This is an 1985 supra with a 5m and about 250000kms. I'm doing a 7m swap so this engine doesn't mean much to me. However the car has to undergo a Saskatchewan safety before i can register it and it would be easier to get it safetied while the 5m is still in it. I'm not sure about the laws on engine swaps, has anyone had any difficulties passing laws with one? If anyone would know what causes these scores or what further tests i could do to narrow this down it would be very helpful.
Bad piston lands on 4,5,6 pistons or just valves or burnt it can be both. Not to rule out a real bad headgasket either.
Was that a dry or wet test. Do both see if they change. Also you can pressurize the rad to see if there is a hiss from those spark plug holes. easy way is to put you comp tester on one hole at a time and see if has pressure when you add presure to the radiator.
As for laws on engine swaps here it needs to be same year or newer engine.
1 - 2 of 2 Posts
