1 - 5 of 5 Posts
Hello,
I need a W58 for a future build and i might have found one, however, I'm not sure if its a W57 or a W58 and the owner also doesnt know. On the Supra wikipedia page under MK2 and then powertrain it sais the european models with a 2.8 liter can have both a w57 or a w58, so how do i know which one it has. The engine in the car is a 5m-ge. could it maybe be that only the 5m-e came with a w57?
anyone who can help?
It sounds like the only reliable way to tell is to check 5th gear ratio
W57: 1st 3.285:1, 2nd 1.894:1, 3rd 1.275:1, 4th 1:1 5th 0.861:1
W58: 1st 3.285:1, 2nd 1.894:1, 3rd 1.275:1, 4th 1:1,5th 0.783:1
http://www.retrotech.co.nz/Tech/Toyota-boxes.php
The Retrotech web site indicates:
The only true way to know which set of ratios you have is to count them. Here is an example of what to do with a W* series box.
1. Count the splines at the output shaft of the box.
2. Put in gear, not 4th cos thats always 1:1, but one of the others. Do all of them in turn.
3. Mark the top of the input shaft and the top of the output shaft with a dot of twink/white-out
4. Slowly turn the input shaft one rotation and get a mate to watch the output shaft.
5. Count the number of splines on the output shaft after one turn.
6. work out the ratio as follows:
ie. 21 Spline out-put shaft,
3rd gear, 1 turn of the input = 15 splines at output shaft
15 divided by 21 = .71
1 divided by .71 = 1.41
So ratio of 3rd gear is 1.41:1
The shifter mounts differ by application so may differ between the same boxes so you can't tell by them.
Discussion Starter #3
To add to this, Ive read conflicting information about the strength of the MK2 W58 compared to the MK3's, will a MK2 W58 be able to hold the power of a ITB 1UZ with around 350 HP? Some people say the mk3's is stronger, others say they're almost the same
There were small design changes after around 1995. Do those make it stronger? That is the debate that no one has answered.
They all break with enough power.
1 - 5 of 5 Posts
