1 - 2 of 2 Posts
Anyone have pictures of the coolant line for the turbo. I am interested in routing the coolant line that goes through the throttlebody. Or if anyone has a good writen explaination that will be greatly appreciated.
Thanks.
Mitch
Really pretty simple. Theres a 5/16" hose that runs from the coolant by-pass tube underneath the intake, between the intake runners, up to the throttle body. Basically take that funky shaped hose out, extend that circuit and add the turbo. Use some imagination to route the lines between there and the turbo to make it look stock if appearance is important. I reversed the coolant barbs on the turbo so they face backward instead of forward and routed the lines around the back of the motor rather inconspicuously. Its not real clear but this is the only image I've got that shows it somewhat.
http://www.celicasupra.com/dupler/6mgte36.jpg
Phil D.
1 - 2 of 2 Posts
