1 - 2 of 2 Posts
Today i put new brakes on all 4 wheels. The problem is that when I am driving it feel like only the front brakes are working and when I come to a stop there is smoke pouring out from the wheels. Any help on whats going wrong or what I did wrong would be great
Make sure all the brake lines are tight at the calipers, if they are leaking fluid onto the rotors when you hit the brakes it will heat up and burn off the fluid. Is the pedal soft? Also how well do they work and what all did you replace? Rotors, pads, calipers, everything? A little more info would help a lot in diagnosing the problem.
1 - 2 of 2 Posts
