I believe this is the case, but I am sure that others will chime in if not:
The block is a 5M type, it has been machined to accept the 7M type longer throw crank. The rods, I think, are unique to the 6M, they are shorter to make up for the longer throw crank. The seals on the crank are 7M type.
I believe you can put 7M rods and pistons in, but the 7M piston tops are designed for a 24 valve engine.
