1 - 15 of 15 Posts
What kinds of oil/fluid do you guys run in your 5m/6m/7m/jz2/jz1 engines window washer fluid, power steering, everything.
I like Boost
5m gets good old conventional 10w30 every 5000 kms. Power Steering is anything that is dextron III ATF. Diff I used synthetic, but you need to get some LSD goop and add it in as well.
5M use Castrol 10W40 and i use dexron for every thing else and the green windshield washer fluid with bug remover.
my 5m uses castrol synthetic 10w30 or royal purple 10w30. i use that blue rad stuff having a mind blank right now on what it is called, and for my windshield washer fluid i use the rain-x stuff plain i know lol,
Right now Super Tech (Wal-Mart) 10W-40 high mileage with a Purolator filter.
Every oil change before this was Castrol 10W-30 high mileage with Napa Gold filter.
Haven't swapped tranny fluid yet, haven't done diff yet, haven't drained and filled power steering yet.
Getting a new clutch master cylinder from SupraKen and I've got Synthetic Dot3 in the rear hatch so I guess it's getting Synthetic haha.
I'm believing more and more that oil is oil cause the car's doing great on an oil change that was a good $15 cheaper than my normal.
Redline 10/40 forever, and Amsoil filters from Dave A...
10-30 cheapest I can get since I have 380,000, used to use QS, castrol, vavoline until I hit 300k, uses some between 5000 mile oil changes. dexton in ps, vavoline in trans and rear.
Really Turkey? The oil kind. Depends on your setup. Why?
Read that F1 motors get 5w-30 syn.
1 - 15 of 15 Posts
