I found a 1990 localy at a good price. Will it work??????
So basically, with that alternator...all you did was put your V pulley on the MkIII alternator and you're set, right?Angkistrodon said:??????......All I know is the 1990 turbo, automatic alternator is almost physicily Identical to the 1985 stock, but with more amps, as far as what extra it is supposed to power I don't know about originaly but here and now its keep ing my 100w fog lights nice and bright.
I seem to have found some mysterious and arcane document somwhere which discribes this exact procedure. In fact, I happened to come across it by using the mythical "search" feature. Golly gee!SupraRacer007 said:So basically, with that alternator...all you did was put your V pulley on the MkIII alternator and you're set, right?Angkistrodon said:??????......All I know is the 1990 turbo, automatic alternator is almost physicily Identical to the 1985 stock, but with more amps, as far as what extra it is supposed to power I don't know about originaly but here and now its keep ing my 100w fog lights nice and bright.
From what I remember, there's a bit more to it than just putting the alternator in the car, unless I'm wrong about that. Anybody know for sure?
I already looked at that section "wise ass" :slapcry: -- as I pretty much know the CelicaSupra.com website from top to bottom.Emohawk said:I seem to have found some mysterious and arcane document somwhere which discribes this exact procedure. In fact, I happened to come across it by using the mythical "search" feature. Golly gee!SupraRacer007 said:So basically, with that alternator...all you did was put your V pulley on the MkIII alternator and you're set, right?Angkistrodon said:??????......All I know is the 1990 turbo, automatic alternator is almost physicily Identical to the 1985 stock, but with more amps, as far as what extra it is supposed to power I don't know about originaly but here and now its keep ing my 100w fog lights nice and bright.
http://www.celicasupra.com/mk3altinstall.html
(runs like heck)
Now THERE is a dose of helpful information... :roll:white_mk_2 said:There's a way to swap the MK3 alternator into an 82-83 with v-belts. It's a two step process,
step 1: remove 5M with v-belts
step 2: install 7M with better alternator and serpentine belt setup
As an added bonus you get 85hp as well
HTH
sure, and your paying for the swap and getting me a rental car for the downtimewhite_mk_2 said:There's a way to swap the MK3 alternator into an 82-83 with v-belts. It's a two step process,
HTH
