Scanners???
to what i think you mean is the check engine light. its on the driver side of the engine bay next to the fuse box. its one of those yellow connectors. it the one with two holes on it usually it has a rubber cap on it. just stick a paper clip or wire between the both of them to bypass them and then your check engine light should blink and give out a code
I hope that helpes you out.
