Alan,the only tps inputs,are thru the wires I had you tap into.If those are all in the correct place,should be fine,unless something alse happened during install.
Unplug the trans ECU,drive it,manual shift thru the gears,for a mile or so.Then plug it back in and see what happens.Had a similar problem with a Corolla fx16,dealer installed a used trans,wanted a warranty replacement.I went up,drove it,did an ECU diagnostic run,worked fine afterwards.
Stay in touch,glad to help if I can.
