I am looking for the wiring harness plug that plugs into the Digital Dashboard Speedometer Assembly.
I believe that it is also used on the inside wiring harness where it plugs into the driver side footwell Fuse Box (all models,not just digital dash).
I only really need the connector, but if you have the inside wiring harness for a digital dash car, I would take that too.
The Digital Speedometer Connector that it plugs into
The rear of the Digital Dashboard - The red highlighted connector is what I want the part for.
The harness connector that I need is similar to this, but with 17 Connectors instead of 13.
The same connector is used on the Driver side lower kick panel fuse box. The wiring harness plugs in here.
Send me a PM if you have one.
Thanks and regards
Dale Z
Supraz
Thanks and regards
Dale Z
Supraz
