1 - 16 of 16 Posts
i need a front passenger side stock brake caliper..
mines a 85 p type johnson.
i want the two caliper bolts with the boots installed in the caliper... and bleeder valves are optional.
come soon and be close by? I hope so. thanks. :thumbsup:
bleeder valve snapped off in the caliper.. any d.i.y. ideas?
theres a 1/4 inch of thread sticking out...
You can try to use an easy out to remove what's left of the valve. Maybe a little heat will loosen it. PM me if you don't find one local.
there is just one bolt that hold the caliper.
hmm ok ill check out Easy Out thanks omkar.
edgar! you are right! i mean the one bolt that's showing.
... i snapped the head of that off in rear caliper.. i didnt get that out either yet actually.. haha.. more pb blaster!
ohh i get it reverse threading! my dad was telling me about that
reverse??? i dont nothing about any reverse thread in our cars, maybe i am wrong, specially in calipers or bleeders.
well those ezy out drill bits is what I meant. i need some. or a caliper.
The easy out is like a reverse threaded screw-----not a bit. You drill a hole in the snapped bolt and screw the thing in .....in reverse. The easy out should dig into the bolt or valve and remove it.
You east coasters should know Kevin has all the MKII parts.
I just got and email from Rockauto, and they are having close out pricing on calipers, for good prices. I almost bought a couple just to shelve them for the future.
1 - 16 of 16 Posts
