1 - 13 of 13 Posts
The easiest one to find are the carbon fiber one from Raptor/Advan.
Good steel ones are rare.
Discussion Starter #4
I know about the CF ones was just trying to find something decent stock even if needed a little work, its for a second MK2 build
Whenever you buy one make sure to have them remove the seal to inspect. Usually what you see in rust is just the tip of the iceberg on these. They usually start at the bottom of the seal and rust outwards to the surface so once you can see it its pretty terminal at that point.
Discussion Starter #8
Thanks for the advise its appreciated my friend , what causes them to rust from under the seal? does debris and water build up there or something?
Hi, i was looking for it and i wonder if i got rid of it ...can't remember but here are some pics of other stuff i have for sale, just in case you need something else, sorry.
Water gets in there and cannot escape. And since the steel edge dont receive too much paint....
When I reassemble mine after paint in 2004, I've put silicone in the bottom of the seal opening before sliding the panel into it.
1 - 13 of 13 Posts
