1 - 20 of 26 Posts
I have an 83 L-Type. I need the harness with connectors to plug into the turn signal/headlight stalk.
I am located in San Diego, CA
Thanks
Pictures attached:
14943
Reactions: ddd228
Be patient. Some of our members have a large parts stash of '82-83 parts.
I won't name names.
Reactions: AJ
Discussion Starter #3
Bump
Mainly looking for the male side of the connectors but a partial harness would help. Thanks
Discussion Starter #4
Bump
A full dash harness is fine with me too as long as connectors are included
Discussion Starter #5
Bump please guys
Does anybody out there have what I need?
Discussion Starter #6
Bump...
Somebody out here has got to be able to help
what's wrong with the old harness? i had my hi-beams go out because of a failed solder joint I was able to fix... Finding parts is getting hard, try calling your local wrecker
will
Discussion Starter #8
will
The original end of the turn signal stalk broke off and the previous owner chopped the original harness up and wired in some janky auto parts store switch just to make the headlights work. None of the parking lights or dash lights operate with the switch. That’s why I need the connectors.
Discussion Starter #10
Discussion Starter #12
Discussion Starter #14
I do. I'd need to rip open a complete steering column and check the quality of it.
OK. Could you send me some pictures of the harness and connectors? Then we can sort out a price
Discussion Starter #15
Bump
I have a box full of various '83 harnesses, all except engine harness. Would like to sell the whole thing rather than take it to scrap yard for the price of the copper. Make me an offer for the whole box or just the wirng you need. however I suspect that bit of wiring would have been removed and remained connected to the switch assembly, and was probably sold with the switch.
Discussion Starter #17
I’m not sure the size of the box in question and how much it contains...
Can you PM me a picture?
Discussion Starter #19
I think the connectors you want are an integral part of the switch assembly ...
I have a new switch assembly with the turn signal/wiper controls stalks. That’s the one I pictured in my first post. I need the other side of those connectors, the body side.
1 - 20 of 26 Posts
