Well Gentlemen,
I posted a reply here earlier in the day on Sunday, February 6th, only to check back later in the day and find it gone... The post was in response to the question "How to determine the proper speedo gear combination," which had been posted by Leslie (that post also disappeared).
Well, the first portion of the response is for informational purposes only - unless you are bored one night and feel like doing some mathematical computations. The primary variables utilized in speedo gear determination is speedo and tire revolutions per mile (RP/Mile), along with tire height and gear ratio. The computation matches 1000 speedo RP/mile to (x) tire RP/Mile. This ratio of course factors in tire height and axle gear ratios. It goes something like this...
Speedo Gear Calculator
1.) Determine Tire Diameter ( 225 x 60 x 14) = 24.63"
2.) Multiply Tire Dia. by pi ( 24.63 x 3.1416 ) = 77.38 tire circumference
3.) Divide one (1) mile into inches or multiply yards by inches (1,760 yards x 36 inches ) 63,360
4.) Divide 63,360 by 77.37 ( 63,360 / 77.38 ) = 818.8 RP/Mile of tire
5.) Multiply tire RP/Mile by Axle Ratio to determine driveshaft RP/Mile ( 818.8 x 4.30 ) = 3,521
6.) Divide by 1000 speedo RP/Mile (3,521 / 1000) = 3.521 (Round this number to 3.5 - this is the ratio you want to achieve).
You will now need to research the available gear ratios for your tranny and determine which combination will work best. My 86 Supra came with a 4.30 rear gear and a 35/10=3.5 speedo gear set. When I went to the 3.90 rear gear I chose the best available speedo set which was the 31/10=3.10. After doing the calculations I found myself at an actual ratio of 3.19, which ends up at a 2.8% error (3.10 / 3.19) x 100 = 97.2 or 2.8%. After correcting for my taller tires (25.1") I recalculate a speedo error of only 1.0%. Supposedly +/- 3.75% is an acceptable error percentage. This equates to 3/8 of one mile error for every ten (10) miles traveled.
I made a more thorough presentation the first time, but hopefully this still helps in your quest to find the proper speedo gear sets. If someone would like, please save this info for others that would like the reference.
Regards,
Carlos
