Automatic Tranny Noise
1 reading
1.1K views 7 replies 4 participants last post by  FuTaRa_DaN
#1 ·
I own a 85 Automatic and when I put it in Reverse and start moving it begins to make this squeek noise "squeeka squeeka" and I can't figure it out... the car has 182,000. Any one experience something similiar or know what this is?
Thanks
#3 ·
Only in Reverse? When you shift to reverse, does car hesitate before moving-If so, How many beats-a one,or a one and a two(Best Lawrence Welk Voice)-Does Sqwak occur only when in motion, or as soon as you shift-Does it stop, or fade out-So many questions-
#4 ·
1)Yes only in reverse
2)It sorta jumps a lil bit
3)The beats are a one and a two
4)It only occurs when in motion
Thanks,
Dan
#6 ·
Sqwak you here is probably lack of fluid pressure to reverse clutch-No easy fixes-Check any lines for blockage-Pump or internal metal wear-worn out old parts-is usual cause
#7 ·
Can't help you but you are aware that when shifting from forward to reverse or vice versa you MUST to be at a full stop, else you put tremendous stress on the transmission as told to me by the friendly transmission mechanic as he was putting in a new torque converter.
