Okay, I know that this has been covered and that the 5m head will bolt up to the 7m block, but what all is needed in order to do this? Eg. 5m rods/pistons, etc.
Thanks.
Thanks.
Attached to a 6M? :zzzzz: Naw seriously you'll probably have a hell of a time getting just a 6M pulley unless an importer or a member here is parting a 6M. At the end of the day unless you have a compelling reason to use a 7M block its probably cheaper/easier to get a 6M. Also if you are going turbo with the new motor I'd just do the 7M conversion and get it right in the 1st place.sil_ver.dra_gon said:where would I find a 6m crank pulley?
And the problem with that would beeeeee?? You couldn't pay me enough money to get rid of my 5m head...even when she gets boost!!SliP said:unless you have a hard-on for the 12 valve sound.
i never said it was a problem at all. I love the sound. notice my edit where I call myself an idiot?karaki said:And the problem with that would beeeeee?? You couldn't pay me enough money to get rid of my 5m head...even when she gets boost!!
sil_ver.dra_gon said:Will the 6m use the 5m ECU/WH? Basically, I don't have the cash or time for a 7m swap because of what's involved, but if a 6m just drops right in and uses all the 5m stuff--ECU, wiring harness, a/c, etc.--then i might do that.
Yes, the 5m ECU and harness go well with the 6m. You can even use your 5m intake and egr on the 6m if the smog nazis in your area require stock smog shit. In fact, the average eye wouldn't know that your 6m was not a 5m once it's in place.sil_ver.dra_gon said:Will the 6m use the 5m ECU/WH? Basically, I don't have the cash or time for a 7m swap because of what's involved, but if a 6m just drops right in and uses all the 5m stuff--ECU, wiring harness, a/c, etc.--then i might do that.
