I used search.
If it's just the brake light staying on when the e-brake is disengaged, checking the fluid and pads was suggested.
If it's the brake and the charge light on, the volated meter should read below 12v (mine is slightly below 12v, but not much) and I should check the alternator/ voltage regulator.
Is this correct?
The car's voltage readings had been a bit high since I got it. While driving, it would be sitting around 13 or 14v. The car has sat about a week in 100 degree Oklahoma summer weather and I decided to drive it today instead of my Benz. I noticed this immediately after startup and thought the battery was just slightly low and that driving it might give it a charge but after 30 miles of driving to work, there was no change in the voltage meter.
What do I need to do this weekend to fix it? Get a new alternator and battery?
Is this correct?
