Me and another CelicaSupra member, Turbosidosis, swapped a w58 into my car over the past few weekends, but we are having a problem with it shifting. The car is a 85 with a 5M and W58, and I am using the S3 short shifter. The flywheel was resurfaced and a new nonturbo 7M Exedy clutch, pressure plate, throw out bearing, and pilot bearing were installed.
The transmission will shift through all the gears alright with the engine off, but once the engine is started it does not want to go in gear. I can put it in first gear, start the engine and drive it as normal, but still wont want to shift. Also, when in first, the car will creep a little bit like an automatic. So, I believe the clutch is not disengaging all the way. The master cylinder is full, and it nor the slave are leaking. I get plenty of throw on the slave and I also adjusted the clutch petal. We greased the clutch fork, throw out bearing, and also the transmission shaft. I worked the grease in well on the trans shaft and I made sure the clutch disk moved smoothly on it.
I really feel it's the grease on the trans shaft that is causing this. =[ Does anyone have any ideas of what may be the problem or how to fix it!
Thank you!
Thank you!
